Try this custom css in theme panel > custom css: http://screencast.com/t/ywNHLkqC5ddi
.td_block_wrap{
padding-bottom: 0;
.td_block_wrap .td-next-prev-wrap, .td_block_wrap .td-load-more-wrap {
margin-bottom: 10px;
The theme have fixes values for its span colons and changing these values will affect the layout. You will need lots of customization such that theme’s blocks be displayed fine.
We can’t offer customization services at the moment so if you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you.
To place ads outside the page content you will need a new container in header or footer, it depends by ad’s code, and some css code for ad’s position on the page. You can use theme’s custom css spot for that code, but the html structure must be created in theme’s files: http://screencast.com/t/eJiayn0g4R8J
Hope this help.
