Please try to disable all your plugins except visual composer, clear cache and reset cdn files. This will rule out a plugin conflict. If the problem is still there, you can try to increase your system status parameters: https://forum.tagdiv.com/system-status-parameters-guide/
Let us know how it goes.
i observed that someone who wrote the article, with some way, deleted the sidebar (i’m not sure about this, because the backend from this article didn’t opened correct) , i have created a new article with copy paste the contents from front end to the new article, and the article is working correct now.
With the new article (and all other article) working correct at backend is there a possibility to have problems with an extensions?
Is there the need to increase my system status parameters?
Do you have some advise, what may be went wrong?
thank you
Hello geolits,
Please try to increase the system status parameters and see if after this your problem is still there. Please follow this guide to increase the system status parameters: https://forum.tagdiv.com/system-status-parameters-guide/
If you have issues with php.ini, please contact your hosting provider and let them know what you are trying to do so they can point you to the correct file.
Thank you for the message!
