Hello, i have the following problem. I ve succesfully instaled the theme, but there are two things i cant edit, that was a part of my web before i install the theme and seems like it become part of the code but it s hidden.
The first thing is a visit counter that apears in home page and in every article, i cant remove it.
The second a disclaimer in a really ugly yellow color that was before comments that appears in every article wth the following text: ”
La Noticia Sur
IMPORTANTE !!! info@lanoticiasur.com.ar, NO tiene responsabilidad alguna sobre comentarios de terceros, los mismos son de exclusiva responsabilidad del que los emite, info@lanoticiasur.com.ar se reserva el derecho de eliminar aquellos comentarios injuriantes, discriminadores o contrarios a las leyes de la República Argentina.
More Posts”
The website so you can check it is http://www.lanoticiasur.com.ar
I need to remove this two things to finish the configuration of the newspaper theme
Sorry if my english is a little bad, my natural languaje is spanish.
I just checked your website and I can’t see the counter that you refer -> https://i.imgur.com/ozcHMEv.jpg
Also, I can’t see the yellow block in the Single Post Template -> https://i.imgur.com/ARMImqi.png
