Problem editor backend and frontend :(
Hi, I just purchased the newspaper template 7. I started to edit, however I can not edit my main page, neither in backend nor frontend.
Can you please tell me what’s going on?
I have wordpress version 4.7.3 and visual composer version 5.1.1 I just bought it.
The front-end editor was disabled in our theme so you can only use the back-end editor.
Your issue could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
