Problem entering the articles
Fatal error: Uncaught Error: Call to undefined function get_post_datetime() in /home/u315997999/domains/praxisrevista.com/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php:671 Stack trace: #0 /home/u315997999/domains/praxisrevista.com/public_html/wp-content/plugins/td-standard-pack/Newspaper/parts/single/loop-single-4.php(32): td_module_single_base->get_item_scope_meta() #1 /home/u315997999/domains/praxisrevista.com/public_html/wp-content/plugins/td-standard-pack/Newspaper/parts/single/single_template_4.php(52): require_once(‘/home/u31599799…’) #2 /home/u315997999/domains/praxisrevista.com/public_html/wp-includes/template-loader.php(78): include(‘/home/u31599799…’) #3 /home/u315997999/domains/praxisrevista.com/public_html/wp-blog-header.php(19): require_once(‘/home/u31599799…’) #4 /home/u315997999/domains/praxisrevista.com/public_html/index.php(17): require(‘/home/u31599799…’) #5 {main} thrown in /home/u315997999/domains/praxisrevista.com/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php on line 671
I need help to solve this problem on my website, thanks
Unfortunately there is a problem with the new option add in theme panel for disable the schema article, this interfere with preview draft, in order to fix this problem you’ll need to make some changes in theme file or deactivate the schema articles from here: https://www.screencast.com/t/0E3IucACC You will have to check that in order to deactivate the schema, this issue will be fixed in the next update.
The file are wp-content/plugins/td-composer/legacy/common/wp_booster/td_module_single_base.php -> https://i.imgur.com/EMWC74l.png add “|| is_preview()” -> https://i.imgur.com/78beFgC.png
wp-content/plugins/td-cloud-library/state/single/tdb_state_single.php
-> https://i.imgur.com/WIIKHSU.png -> https://www.screencast.com/t/VbigQIINRB
or you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look and make the proper changes for you. Include a link to this topic in the email.
Thanks, apparently I am solving it with the uninstallation and reinstallation, but another problem persists that I do not see how to solve it, about the translation and those embedded in the sidebar inside pages and entries. I hope you can help me, a hug.
i send some pictures
https://drive.google.com/open?id=1udXkhxb7xx0lEOUOBJXEw_eYdXao499U
These are the social counters, this can be edit using tagDiv Composer and using our guide from here -> https://forum.tagdiv.com/tagdiv-social-counter-tutorial-2/
Hope this will help you!
