Problem Fashion Demo Theme
First of all, congrets with launching the new theme!
I’ve bought Newspaper 4 a while ago and now we installed Newspaper 6. After installing Newspaper 6 we installed the fashion demo theme, the problem now is that on my own website all kind of content of the Fashion demo theme is placed, combined with my own content. Obviously I only need my own content. How can I install the Fashion Demo Theme, without the demo content. Thank you very much for your quick reply!
Best, Myra
Ps; We are aware of the function ‘include content’. But when we do this, the theme looks really sober and not at all as in the demo.
I am not sure what you mean but the demo from here http://screencast.com/t/GhZPOL0QY are made with the same theme as a guide to help the user to create his own pages and posts. If you already have your own content, it’s not necessary to install a demo, because the demo pages will be published automatically, and the theme works fine without any demo installed. You can uninstall the demo to remove the imported pages from your site.
Hope this will help!
  • This reply was modified 11 years by Andrei L..
Hey Andrei,
Thank you very much for your input. Unfortunately it is not helping us since we do want the demo so we need to install it.
Will wait for the reply of Tagdiv 🙂
Thanks Again!
Andrei is from TagDiv …
seems like you want to
a) uninstall demo content
b) install demo “styles” and *NOT* the content.
c) then customize for your desired layout.
Thanks Chris!
@MissMyra
Not really sure what you want to do, there is an option to install the demo without the content – http://screencast.com/t/Llv4BYBbY5d so like you can see in the screenshot it will import only settings like fonts color(no articles, pages, menus…) – depends what demo you install. Also if you want to uninstall you can do this from the same section – http://screencast.com/t/uiQJdyH8NG so it will remove all the content added(if you have installed demo with content) and your theme settings will be on default, you will have to customize your self.
Hope this helps!
