Problem filtering post
Im using a widget Block 1 to show the “most Popular content”, works fine, BUT the filtering is not working, i have some post that i dont want to show, i followed the tutorial steps but is not working, the widget is still showing all post (without filtering)
Here some screens:
https://gyazo.com/20f06410bf49fa68c4a438a1fa0b2628
https://gyazo.com/023c7214c1f3c969e393c5efab196e49
That post sorting option requires the Jetpack plugin and stats module from the plugin to work. Use the default Popular (all time) or Popular (last 7 days) post sorting
– https://forum.tagdiv.com/block-settings-guide/
Please note that the popular sorting require post views to be active
– https://www.screencast.com/t/H2126O67
Depending on these post views the most popular posts are calculated and displayed. The posts with the most views will be displayed in the block.
If caching is used on the website this option will ensure accurate statistics
– https://forum.tagdiv.com/ajax-view-count/
Thanks Simion, please read what my problem is.
Your answer is from a template, everything you mention I read it and I did. please help me, this is my first reported problem.
About what you mention:
1.- Naturally I have already operating the Jetpack with stats module, my configuration of the Widget is Popular (last 7 days).
2.- post views is already active
3.- I have no caching problems
Please note that my problem is that THE FILTER does not work, I apply a filter and it does not apply, the rest works well.
Sorry for the confusion. Please note that the popular sort order that uses Jetpack will not work with other settings, or with pagination. It will all be processed by the plugin. No information that will be entered in the other fields for the block that uses this sorting option, will be taken into consideration
– https://www.screencast.com/t/BLxAeGGsGQ6y
There may be an option to exclude specific posts, maybe something like this
– https://jeremy.hu/jetpack-remove-top-posts/
