problem firefox PC/MAC
Do you still have this issue?
I have checked your site on Mac using Firefox latest version and found no issues regarding your site’s layout: http://screencast.com/t/uSZShgOs0V
Please let me know!
yes.. i still have this issue. I can’t understand why… i have last firefox update. 🙁
Are you sure using Mac and Firefox generates this issue? I have tested your site again but still didn’t found any issues: http://screencast.com/t/62LKxbmZLS4q
You should also consider disabling the js minifiy option: http://screencast.com/t/8cMh6rFQT9m
Please also try to deactivate all plugins empty cache files and purge files if you use any cache or CDN plugins and check for this again.
Latest versions of Firefox on both Mac/PC have some oddities in parsing Ajax and “compressed” or minified content. We ran into this with our ecom system with mod_SPDY running on our server; works great in every OS, browser, etc., EXCEPT for Firefox, with no workaround I could figure out. Might be issue with current build — since if it works in Chrome and Safari (latest), it should work everywhere … but Firefox … maybe not.
So, some kind of minification or compression or other thing causes Firefox to get lost in some way, and only solution we’ve found right now, is to turn off the optimizations so Firefox sees the complete HTML and can read everything in the right order; or it just won’t work with some things.
HOPING the next version will fix that. (Upshot — might not be just you!)
Thanks Christopher sharing that info!
Have a nice day!
