Problem for remove H1 td-logo
Hello, i want remove H1 automatic on my TD-logo (title or alt)
How can i fix it ?
I use my personnal H1 for all the page
i have open logo-h1.php but i don’t understand how can i disabled any H1 on my logo and on my alt logo
i have change all true to false but can’t fix this problem
If you want to remove/replace the h1 from logo you’ll need to go in wp-content/themes/Newspaper/parts/header/logo-h1.php -> https://www.screencast.com/t/65b9huuah5I
Hi, I have make this before the last update, and all work good.
Now, with last version, I have only 4 file in that directory.
– header-menu.php
– header-style-1.php
– logo.php
– td-login-modal.php
I’m tring to edit logo.php, but nothing happen. How to?
Thanks a lot
Fabrizio
Most of the theme files were moved into the tagdiv composer plugin as per the requirements of envato: https://help.author.envato.com/hc/en-us/articles/360000472383-WordPress-Theme-Requirements.
We wrote an article on the subject here: https://tagdiv.com/updating-the-core-of-tagdiv-themes/
In order to edit the logo-h1.php you need to go in wp-content/plugins/td-composer/legacy/Newspaper/parts/header/logo-h1.php
Work!
Thank you very much!
Fabrizio
