Problem Header Mobile Sticker.
Hello, I am changing the style of my website and I do not get the header in the mobile view option, look and stay when you move the screen, attached video of the process.
video
  • This topic was modified 4 years by ludyma.
Please try first those options for sticky header -> https://forum.tagdiv.com/header-manager/ -> https://i.imgur.com/h5Pbsix.png
If you want to use the sticky row option make sure that all elements that you want to be sticky are on that row.
Also, on mobile, make sure that you do not have some custom settings set in css tab -> https://i.imgur.com/rmz0R2N.png -> https://i.imgur.com/yMfGAjF.png
Hello, the truth is confusing, performing it by the different option and this is another different option, I already resolved the problem as you suggested to the options of the option by the Tagdiv Editor, but it is confusing and gerneous error according to how you do it, you need a Good theme manual is complex and also each update changes a lot, it is urgent.
Indeed the theme has many options and with each update there are others. we try to cover the most important options, but there are still quite a few that are not covered by the documentation. Now most of them display a gif -> https://i.imgur.com/FhC4xuO.png as they should act but depending on the various settings that are made on the element, they may differ slightly.
Hello, you could remind me where the option is not to repeat an entry.
Why does Facebook option not come out in Login from Mobile as in PC?
If you are referring to unique article option -> https://forum.tagdiv.com/unique-articles/
The Facebook login option it is only on “Menu login” element -> https://i.imgur.com/OwnBQBI.png by default on mobile it is not using that element.
