Problem importing Cloud Templates
Hi, I have a problem when I import Cloud Templates for Single Post, when I import a template (example, Single Post Template 28) it has a sidebar, but when I apply it in the Theme Panel > Post Settings > Default post template (site wide) the sidebar disappears and shows below the post.
Can you help me to import correctly the template or showing me what values should I put to have the sidebar show correctly in the template please?
Pictures:
– Cloud Template showing correctly in tagdiv composer:
https://imagizer.imageshack.com/img924/2976/5WeCXB.jpg
– Cloud Template showing correctly in “preview”:
https://imagizer.imageshack.com/img923/7909/5QZ6PF.jpg
– Cloud Template template applied site wide and not showing the sidebar in the post:
https://imagizer.imageshack.com/img924/398/pB8fEk.jpg
– Sidebar showin in the end of the apllied post:
https://imagizer.imageshack.com/img924/3452/KqYvDF.jpg
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins (theme plugins), also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Please do not use WPBakery with tagDiv Cloud Library, this will not work correctly. Please deactivate WPBakery and import some demos from tagDiv cloud Library -> https://tagdiv.com/what-is-the-cloud-library/ or install a pro demo.
If there is still a problem, please provide me a link where I can inspect it.
Let me know the results!
