I have problem in bbpress style when active WordPress SEO Yoast
when NOT active WordPress SEO Yoast plugin the fourms is like :
then i active WordPress SEO Yoast plugin and it seem like this ???
i need the fix from you becouse i can’t deactivate WordPress SEO Yoast plugin it is so important to me ,
i think that the theme code can fix this !!!!
my site is http://www.twojaws.com/forums/
thank you team
OK Lucian <
WordPress SEO Yoast plugin is NOW Activated in my site :
You can check it ,
I will waiting for you tell you provide me the solution
Thank you
OK Lucian <
You can check it ,
Thank you
Sorry for the delay!
Are you sure that the WordPress SEO plugin is responsible for this? I have inspected your site and found that you have some missing css from a plugin: http://screencast.com/t/0Oggd7Bkdv1
Please make sure you deactivate all plugins and enable just the Visual Composer, bbpress and WordPress SEO plugins then check if this is still happening.
Also remember to empty your cache and purge files if you sue any cache or CDN plugins.
Please let me know of what you find.
you are right Lucian the plugin that cause the problem is
CM Tooltip Glossary Pro+
so after that i’m deactive the box
Only show terms on single posts/pages (not Homepage, authors etc.)
on it <
so evry thing is right and goooooood !!!!!!
thank you for your help ^_^ i love you ^_^
