Dear sir,
kindly check this image.i am not able to add a single post..its converted int text mode.Not able to see visual mode.
Not a single thing is working in edit post section.
https://2.bp.blogspot.com/-EjVsQYyiHl4/WKV04gaACrI/AAAAAAAAF94/m5Mj6hxyl7YsovU1EceQpqjCjpwdMUbewCLcB/s1600/sdfgsdg.png
please help to sort out this thing.
thanks
This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
