Problem in Header and Footer in Mobile
My website’s (http://www.collegeinfonepal.com) header and footer are experiencing problems. Half of the navbar is transparent and the other half is solid black (I want solid black full) and the same with the footer. The problem is only in mobile.
Problem
I just checked now your website and seems that you managed to solve the issue -> https://i.imgur.com/XBzXcc4.png
I’m glad!
Have a great day!
No, the problem is not solved yet. When we inspect our website on the desktop and watch it on the mobile version, it shows no problem. But when we view our website pages from mobile, it still has the same problem.
I just checked on mobile and it works well https://we.tl/t-j2f4FxolLT
I am having exactly the same issue in all my the sites I upgraded to version 12.6.6 that have “sticky” menus!
https://myloyalty.gr
https://sophiasamara.com/ (on sticky)
The row colour in the header does not seem to be propagated – and we have to work with cell colour but this is not feasible all the times.
In this one
https://esp.ecode.gr/
the split colour even goes to the menu style – the page is split into two… similar to the footer.
Something is going on here:
background-color: var(–center-demo-2);
  • This reply was modified 2 years by dimitrisv.
Just to say that I fixed the sophiasamara.com with some custom code because the client could not wait for a fix by you.
.td-footer-wrap{background-color:#000 !important
#tdi_98{background-color:#000 !important
But you appreciate we cannot fix the about 10sites that we are using your theme, with something that will override the bug.
I would like to take a look. Please contact us via email at contact@tagdiv.com and provide the wp-admin access.
I just sent credentials for two of the sites (that are based on different cloud library demo).
Please also include the link to the topic.
I did 🙂
The email was sent 8:44 your time
