problem in header theme
hi!
my website have problem in header like the picture
Even though I have disabled “SHOW SIGN IN / JOIN” in Theme panel
please i want to fix this problem
thanks
Hi mohamedmohriz, if you are using a Pro demo you must edit it using tagDiv Composer, because this is using a cloud templates -> https://i.imgur.com/e2XSoVC.jpg and use the right click to remove the element you do not need -> https://i.imgur.com/nycHdSg.png
If you have other questions, let me know!
I cannot solve the problem this way، because this form “SIGN IN / JOIN” appears in the header of the site pages only for two seconds
Hi mohamedmohriz, pleas provide me a link where I can inspect the “SIGN IN / JOIN”, in this way I will be able to provide step by step how to do next.
ok thank you, tropply.com the problem will appear in the head for two seconds، It appears on the phone most of the time
Indeed is look that this is dismaying for 1-2 second on mobile devices.
As a suggestion you ca do two things:
1. Use a pro demo
2. Remove the code for login from them files if you do not want to use it -> wp-content/plugins/td-composer/legacy/Newspaper/parts/header/td-login-modal.php -> https://i.imgur.com/XdFc9rz.png
Let me know the results!
