Problem in Mobile site
I am purchasing Newspaper theme. Some problem I am facing.
My website address : http://lnx9.cloudhostdns.net/~a9a78e32/
Problems are :
1. When I opening it in Mobile It appears left & some portion missing from left. Its showing only in Homepage. Other category page is OK.
Snapshot: http://lnx9.cloudhostdns.net/~a9a78e32/mobile.jpg
2. I don’t want Latest tab in category section
Snapshot : http://lnx9.cloudhostdns.net/~a9a78e32/latest%20remove.jpg
Please help. Thank You.
1) Please check your homepage again and recreate it in visual composer. If you have a row inside of another row, please remove them as these situations can cause errors. Please use a default layout to see if the issue is still there.
2)You can use this custom css code in the theme panel->custom css box:
.td-pulldown-filter-display-option{
display:none!important
Thank you Bogdan. It’s work fine now. One thing, I want auto publish of my post to my Facebook, twitter pages. Is it possible from Newspaper 6.6 theme.
Hi Barun,
for this task I suggest you to use the Jetpack plugin and its module Publicize.
hi please help me , i was publish 1 tread but coment nor yet
OK thank you thesend. I will try.
