problem in related post sidebar display
In instylebeads any of post description page i am having related post side bar .
But i have error in some related posts
check this screenshot
the silde post don’t have description so some extra code is coming instead of description .
what is the solution for this .. any help ?
  • This topic was modified 9 years by manigowda.
I’m not sure what the related posts widget is. It does not seem to come from our theme though. Please use theme elements and add a block on your sidebar using our theme widgets for the widgets area of WP. The plugin could not be compatible with the theme.
Ok thank you Bogdan B. thanks for your help
