hello, i have purchased the theme and i am trying to setup my theme in rabic language ,but problem is that the theme is not getting fully RTL and especially the logo stays on the left side, for arabic side it should be on the right side
also another problem is that i did all in the documentation but keeps giving me latest articles on home area even i did every single demo but didn’t work
my website is عربي – ينبوع التنوير وحداثة الاصلاح الفكري والفلسفي
Please try this custom css in Theme Panel > Custom Css – http://screencast.com/t/jAXZVpuwryc
.header-logo-wrap {
float: right;
margin-left: 0px;
margin-right: 30px;
You can change to a template without articles like Homepage Blank and add blocks via Visual Composer – http://screencast.com/t/rrHDX6TuIT so it will be displayed only blocks that you add to your page.
Please also consider that unfortunately the version 5 of the theme will not include rtl support. You can still use the theme as it is but unfortunately you cannot updated it as you will lose the rtl support or you can update it and make yourself the necessary adjustments needed. If you can’t use the theme we can offer a full refund, just send an email at contact@tagdiv.com and we will explain the procedure.
Sorry for the inconvenience!
