All the settings in System status are green! , still can’t save , no errors , just keeps loading ! , tried to disable all plugins and nothing happened
my php settings
my demo site is working fine : http://www.libyaninvestment.comm/wp
appreciate your quick reply
hey. we have the same problem… Fresh instalation. No plugins etc.
For me changing php to 5.4.45 solved a problem. I hope it will help also 3rdhub
@3rdhub Usually saving issues are caused by insufficient resources, having the server an WordPress parameters set according to the guide is a requirement
In other similar cases the issue was caused by security plugins or server firewall configurations. Check with the browser inspector in the console while saving settings in the theme panel, see if there are any denied requests
– https://www.screencast.com/t/kWNf8Yvkgl
Please let us know the results.
thank for your reply ,, i got this message when saving ScreenShot
