Problem in the Header Sectiom
I am facing problem in the header section:
– Text is appearing with the LOGO
– Search icon
Site: http://www.hacking-guide.com/
Here is the screenshot: http://i.imgur.com/ETTO9GD.jpg
Please Help
And another problem is that the logo does not stick with the menu when I scroll down.
Hello sudhanshu15,
I suspect to be conflicting plugins. Please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with our theme and rule out this issue. Also, if you need some additional customization through code, please try to remove them and check again the results.
I am using WP-Rocket premium plugin which is causing the problem.
