problem in theme
i have this problem how to fix
http://www.upgulf.com/up-png/xw392672.png
thanks
i have deactivated this menu
http://www.upgulf.com/up-png/prt93208.png
Please try to disable all plugins except visual composer, clear cache and reset cdn files if you use it.
Then try to install a theme demo and see if the issue is still there.
Let us know how it goes and provide a link to your site if you still have trouble so we can inspect it.
The same problem
I think the problem is that the heart does not comply with the Arab
this my web site
http://www.newborntoddler.com/ar
user : khouya59@gmail.com
pass : #EP7MeIk6Jx2eWA&pD6D0DNo
If you can solve problems
thanks
  • This reply was modified 10 years by msaydati.
Hello msaydati,
I have checked your website and I saw that you are using the RTL mode for the theme. Please keep in mind that the theme has no RTL support because it has been designed to be used in this layout, sorry!
Unfortunately, we have no plan on implementing it in the near future. Implementing RTL support in our theme will require 2 style.css files and it will add significant “weight” to the theme. Using the RTL mode means that lots of elements have to be adjusted and this thing involves custom work and we cannot provide this at the moment!
Please try to do a simple search of our forum and you will see that our team offers support only for theme related problems and which not require additional customizations. Please check again our support policy here -> https://forum.tagdiv.com/support-policy-2/
