Problem in Translation
The “translations” page doesn’t work. Nothing happens after I click in the “Load translation” button.
As for what I have seen, this is a common issue with the theme. I tried the workarounds listed in the forums, but nothing worked.
I want to load Portuguese translation.
Can you please help me with the issue?
Regards.
Please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
Hello I have exactly the same problem
Then contact us via email as well and we will investigate your site as well.
I already sent the email with the details, but no further contact has been made. How long does it take to fix the issue?
Regards.
Your site on HTTPS protocol? Api tagdiv does not support the https protocol (which is weird). Therefore, the script not should be loaded. You can download cheat code inspector, but this is for advanced users.
PS. I had the same problem 🙂
Nope, its HTTP only. I’m getting a timeout trying to reach the api server.
Still no update in the language issue. I sent the email with all the details, but no reply was made.
Regards.
https://www.screencast.com/t/B3KuBQTT
We will reply via email shortly. It could be possible an answer is already provided as I cannot trace your email. Please let us kniow if you have not yet received an email and try to send it again and post a link to this forum or your forum username so we know it’s you.
I did not receive any reply yet.
Regards.
We replied via email now.
Hello all,
Unfortunately we could not managed to yet find out exactly why this translation loading from theme’s panel is happening. We will continue to investigate it and fix it as soon as we figure this out!
@gos_ant
Thanks for the info, we will look into it!
Sorry for the inconveniences!
Lucian C.
http://api.tagdiv.com/user_translations/get_translation?callback=jsonpCallback&language_code=az&_=1485429232366
Failed
Connect: Connection timed out: connect
HTTP/1.1
GET
No
/127.0.0.1
api.tagdiv.com/5.2.168.18
Please also contact us via email at contact@tagdiv.com and we will load the translation on your site. We are working on a fix for the next update for this issue.
