PROBLEM in visual composer ( Newspaper 3.7 )
hi,
In visual composer the CSS Animation ( NOT WORK ) Why ?
so please is it work or no ?
and the Frontend Editor not found in Newspaper 3.7 ?
http://prntscr.com/3dbfmc
and i love your new VC plugin to the theme , I think if it work fine the theme will raise up to higher level of rating and population than ever > THANK YOU <
Not work, sorry for the inconvenience! and also the Frontend Editor at this moment is not compatible with our blocks. We still investigate this!
Hi Marius,
do you know when the frontend editor will be available? Could you fix your probs with the blocks?
i hope you get it soon 🙂
cheers from germany
Hi,The CSS animation is fixed in the latest update, about the frontend editor is very difficult to make it because all our block and visual composer have some incompatibility when refresh the blocks data.
