There seems to be a custom code that affects the footer socials
– https://www.screencast.com/t/W5IdL827
That is why they are displayed in the page content, over the ad. If you remove that code the socials will display in the footer.
It seems that you have some additional customizations because some unknown codes are working on your website and that’s why you bring bad results with your footer socials icons, sorry! Try to remove all of these and disable all of the untested plugins if you are using something like this, clear all the caches and check the results. As a quick solution, you can try using the code below and place it in Theme panel -> Custom CSS area.
The code is ->
.td-social-style-2 .td-icon-font {
top: inherit!important;
