Problem inner row
Hi. I have problems adding a new row or inner row. Everything seems wrong. I can not select the options it brings.
I have made some tests with the inner row element, but there is no issue with it
– https://www.screencast.com/t/5mjt3rdrR
Form what I can see in the screenshot the composer settings are not displayed properly for you. Please try as a test to deactivate all plugins except theme plugins and check if this has any effect. It could be the result of a plugin conflict, that is not how the composer settings should display.
Hi.
Already solved. I fixed it by deleting the cache with ccleaner and everything was fixed. I mention it in case someone else happens.
