Problem inserting adsense between article lines
Hi, I have the problem of not understanding how to insert the adv (adsense) in the middle of the article lines.
I have followed all the steps of your guides but the advs do not appear. As you can see I set from theme panel https://ibb.co/MCYPJBq and also in the article I selected default https://ibb.co/vd43xKW
I also went into cloud templates —> single article and set it manually as you can see here https://ibb.co/D1Vqh5H
I also went to cloud templates —> single article and set it manually as you can see here but I don’t see advertising between article paragraphs. After I have saved in cloud templates —-> single article if I return to the single article the codes I have entered, that is always these https://ibb.co/D1Vqh5H these have disappeared as if I had never entered them. What should I do?
Thanks in advance for the support
Please make sure that the code is working and it is written correctly, also check if you hit the button SAVE, so the settings remain there, also the code.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
Thanks for the reply. I have saved everything and I think I have set everything right. I also tried to create a new template different from the one I use now on “add new templates” but the problem remains. Can I send the email referring to this post?
Yes, you can send a link to this topic in order to identify you.
Thanks Bettina!
Hi, I sent the credentials and the reference via the email you wrote me. How long will it take to check? I need to add tags to articles.
We received the email and today our team will most likely respond to you.
Please let’s continue the discussion there.
