Problem Installing Demo and Contact
I’ve installed a demo and content but now i get the following message when I visit the site:
Did you disable any TagDiv plugins?
We’ve got some errors at loading API files. It could happen because of a disabled TagDiv plugin!
Then on the site in the header area I get:
wp_booster error:
td_api_base::mark_used_on_page : a component with the ID: tdm_header_style_3 is not set
wp_booster error:
td_api_base::get_key : a component with the ID: tdm_header_style_3 Key: file is not set.
wp_booster error:
The path of the tdm_header_style_3 header style not found. Did you disable a tagDiv plugin?
and in the menu area:
[tdm_block_inline_text description=”UGxlYXNlxcvbUyMHRoZSUyMENyeXB0b2N1cnJlbmN5JvcgnjBXaWRnZXQ=” display_inline=”yes” content_align_horizontal=”content-horiz-center” description_color=”#ffffff”]
Please advise. I’ve tried uninstalling and starting again. Ive tried uninstalling the plugin ins and reinstalling
I suggest you make a new fresh install via FTP way, remove all of the untested plugins, clear all the caches and check the results. If the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) and Cpanel access for further investigation.
