Problem istalation
I installed the theme , but after installation I see active after blank page . blocks all wordpress
same problem with me
even i mesag thesse guy by mail but they not responding ….
Make sure you upload only the main theme files; don’t install the “all files” zip from ThemeForest… that has docs, psd files, plugins, etc.
You want to install the smaller of the two files on Themeforest, if you’re installing via theme panel with .zip.
BEST WAY TO INSTALL WP THEMES:
Ideal way is still to
1) unzip theme folder “Newsmag” on your HD
2) upload via FTP/SFTP to your /wp-content/themes/ folder
3) upload the plugins unzipped to /wp-content/plugins/
4) switch to default theme from your old theme
5) turn off *all* running plugins
6) clear your cache(s), turn off caching (!),
7) activate the Visual Composer plugin
8) activate the new Newsmag theme
9) launch the theme panel
10) reactivate only the plugins you 100% need to make sure they work (some plugins WILL NOT WORK properly with WP 4.01 until you update the plugins!).
Clear the cache in your WEB BROWSER FULLY and restart web browser; this clears any CSS/Java used by your previous theme admin, and theme, so that you see the new CSS/JS properly (seriously, this is cause for huge number of “my new theme doesn’t load right” or “admin panel doesn’t have any boxes!” errors).
If you’re running WordPress older than 4.0 be aware there is a very serious cross-site scripting vulnerability (e.g., WP 3.9.2). You should be running WP 4.0+ to use this theme properly.
This is standard practice for switching to a brand new theme and good habit to get into doing it this way to ensure you clear cobwebs on old, and cleanly move to new.
Hope that helps! 🙂
Chris
  • This reply was modified 12 years by simchris.
I did all this , the same problem on the previous template … no problem … you help me ?
same problem here. I get only a blank screen. Is there a list with incompatible plugins?
It was the Social Counter Plugin from tagdiv.
I found the answer here: http://themeforest.net/item/newsmag-news-magazine-newspaper/9512331/comments?page=5#comment_8439735
