Problem js www.ecomesifa.it
Good morning, sorry, but I have a problem with your template. Using the litespeed cache and enabling the “Defer Javascript” entry, the first time you open a page, does not work in the search button, or the menu button on mobile. But then, continuing the navigation and opening a new post, after loading, everything works. How could I fix it? the site is https://www.ecomesifa.it. Thanks
Hello Federico,
Please notice that plugin used by you has not been tested with our theme and also, we cannot say for sure if it will work or not with the theme, sorry! Also, notice that we cannot provide support for untested plugins, sorry! Try using only of our tested plugins if you want to bring best theme results.
