Problem loading images from library
Hy guys!
I’ve been having this same problem since I updated my website to the last wordpress version.
First, the images from the library would not load when I wanted to make an article. If I wanted to access the media library, the images only appear on list mode, not grid mode.
I solved this problem disabling jetpack plugin.
Now I have the exact problem again but this time the plugin that causes this problem is visual composer and well… I can’t make anything without visual composer. If I disable it I can access the media library, but if I enable it, I can´t. Also, when it’s enable, it doen´t load any model.
Any suggestions?
Thank You!
Please make sure you’re using the latest them’s version (V 2.1.1) which is tested with the current WordPress version and works fine. Also try to deactivate all plugins, leave just Visual Composer and switch to a WP default theme, clear all caches ant test again. Let me know how it goes and if the problem persist address us via email at contact@tagdiv.com and provide wp access so we can inspect this issue, also include a link to this topic.
Hello Andrei!
Thank you for your answer. Actually, I’ve already tried all those solutions and didn’t worked. I will send you an email with the access to the backoffice. The website is: http://www.1001topvideos.com/
Thank you so much!
Hello Again Andrei!
I just give you wp access. Please check your email contact@tagdiv.com.
Hi master2501,
Sorry for the delay!
I’ve replied you via email now!
