Problem loading TD Composer
I can create new pages and everything works fine. But when I try to return to the page after I have saved it, I only get the spinning wheel. There are ads that I embed via the html-element that use https and if I look into the JS-concole it warns that it does not find jquery.
Any ideas? The url is http://www.football.at
I had this time and time again. Got told to clear cache, inactivate all over plugins etc and try again but I had no look.
As a last option I reinstalled the whole theme and up to now, it has been working fine.
Thanks, I have already tried to disable everything except the composer. Did not help.
I will try the reinstall.
Fatal error: Access level to tdc_composer_block::get_block_classes() must be public (as in class td_block) in /home/xhemalah/public_html/wp-content/plugins/td-composer/includes/tdc_composer_block.php on line 0
Hello Xhemal,
Please try to re-install the theme via FTP ay and ensure that you are using the right and correct theme version which is available from ThemeForest. Clear all the caches and check the results. Also, please notice that we do not recommend simultaneously using these page builders because might appears some errors.
