Problem loading the newest Post of an Category
I do have an problem with one Post.
https://football-austria.com/dragons-verlaengern-mit-jeffries/ => That’s the new Post. Posted with category “AFL”
But on the Main Page nothing is displayed. Do you find any mistakes I did?
I purged the cache several time. But nothing changes.
Home Site: https://imgur.com/a/693bKGV
Tagdiv Composer: https://imgur.com/a/Tns4TYV When I press save it loads. But then nothing happens.
I see that post in the top grid at the moment – http://prntscr.com/l7tbbt
Also in the category page – https://football-austria.com/category/afl/
But not in the block you mention further down the homepage, which is filtered to show posts from the respective category.
If you use a latest sorting for the block, then the latest posts should appear in it.
Usually a form of caching could interfere with displaying the latest posts, but since you cleared it that may not be the case.
What if you try and edit the page, remove and re-add the respective block, or switch the sorting to a different one and back. Then save the page and check if this has any effect, let me know.
I changed it to all categories purged the cache and it loaded up other posts. Then I switched back to the category AFL. And again it displays the same 3 posts.
The strange thing is when I switch categories inside the tagdiv composer it will load up the new article but it won’t save it. After saving it will keep at the old 3 posts.
Don’t know whats going on with this.
I found out that the sorting option. Most commented. Don’t work aswell.
It is sorted the right way. But it displays just random post in this category…
https://imgur.com/a/IGpksk9
Any ideas what is causing the issue? I purged the cache severall times. And it will display the same 3 posts.
Update: I found out. That all sorting option on the website are not working…
Is this a bug at on my end or an bug with the template?
I made more tests including with the Most commented sorting, seems to work same as before
– https://www.screencast.com/t/S2faGt6g
We could take a look on your website, send us an email at contact@tagdiv.com and provide admin login. We will test the sorting options in a test page, to try to identify what is happening.
Please include a link to this topic in the email.
I sent you an Email. Please confirm.
