problem mixed content
Mixed Content: The page at ‘https://elysiumpost.com/governo-mattarella-convoca-casellati-potrebbe-ricevere-mandato-esplorativo/’ was loaded over HTTPS, but requested an insecure image ‘http://elysiumpost.com/wp-content/uploads/2017/11/footer_bg.jpg’. This content should also be served over HTTPS.
chrome give me this problem i tryed also to go in theme settings and delete this img but i have always this problem
This doesn’t have anything to do with the theme. The problem is that your site has an SSL (https://) certificate and the background that you have put in the footer has an http:// url. If you replace the url from http://elysiumpost.com/wp-content/uploads/2017/11/footer_bg.jpg to https://elysiumpost.com/wp-content/uploads/2017/11/footer_bg.jpg in the theme options, it will render the correct background and eliminate the mixed content error you are getting.
i have replaced http to https but it stil not work
If you make the switch to https, then you will have to remove all of the images you previously added to the background or logo in the theme panel as they were saved as http when originally added. You must replace them with a https link.
