Hello
Problem with the menu on cell phones is a problem encountered by many people. The problem is not fixed and I’ve read over 300 messages and I’m not even halfway through the messages about problems with the mobile menu. No solution
isn’t there a problem with the theme?
Hello @Fontaine!
Can you please provide more information about your issue? Did you try what I’ve suggested to you?
Hello @Fontaine!
Yes. For that button, you should have set a menu in order to display something.
If you can’t handle to solve this issue, then contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– the license certificate and purchase code
