Problem of displaying blocks in the page constructor
Hello
I have a problem between my theme and the plugin visual compose, When i go into my home page mounted with visual composer which contains many blocks,
I have just 1/5 of the blocks that are displayed. It annoys me because not seeing all the blocks it is impossible for me to modify on my page.
I do not know if the problem comes from the theme or the plugin, I reloaded the latest versions of the theme and the plugin but the problem is still there.
Need your help please it makes the day that it lasts and I have an urgency to correct on the website
thank you
Hello, I have this as well….
Imported a DEMO and customized it from there… removing some blocks, adding others.
All’s well except that there are 3 blocks between the footer and the last one shown in the Visual Composer. It’s showing Latest Articles in main area and sidebar has Stay Connected, Adverisement, and latest Posts on sideaber.
How do I remove these blocks and why are they not showing in Visual Composer?
Hello all,
Notice that the Latest Articles modules are comes from Pagebuilder+Latest Articles+Pagination as the page template and that’s why it is not showing on Visual Composer. If you want to remove this feature, you simply switch the page template to another one, like Page Template Default.
If you need more assistance in this regard, please provide your websites so I can take a closer look inside them.
By what private channel I can provide you access to my site in order to view me the problem because I do not see how to do it
I also have this issue. It seams that Visual Composer (no matter which version) is not working properly with the latest version of the Newspaper Theme (7.6)
I solved my issue by deleting the theme and composer plugin, uploading latest theme, then installing composer plugin. Now works fine 🙂
  • This reply was modified 9 years by hempmag.
In my case the sidebar was moved from the Visual Composer page of the front page to the front page widget area. Strange, but working 🙂
