ONLY on screen 21 “I have the problem that you see in the image.
In smaller screens there is not all that empty space.
How can I correct?
Thank you
https://www.awesomescreenshot.com/image/3893970/2f0371f8bb1cfe9e922775e729db09dc
I have checked your website and I saw the big white space which seems to come from your page configuration with Visual Composer. As a quick solution, try to use the code below and place it in Theme panel -> Cusotm CSS area.
.home .vc_row-flex{
min-height:0!important;
Hope this helps!
