Problem on logo footer and preview articles dimension
Hi i am setting up my web site but i have some problem of visualization. I’d like to set logo in all device(https://www.loom.com/share/bd13fa87456e4e42b8698826ddca072a), preview articles on home page are not the same size, font inside article is barlow but on preview there is another font(https://www.risorse.news/)
Thank you
  • This topic was modified 3 years by Opes.
You need first set the logo set for the desktop version this will be inherited for tables and phone, but you can adjust it on each version.
Thank you Anamaria, is what i’ve done but isn’t working…what about preview article size and font?
  • This reply was modified 3 years by Opes.
I recommend you to use the Single Post Template from tagDiv Cloud Library and there you can edit the template with tagDiv Composer. Please try to edit the Single Post Content and set the font-size for default blockquote => https://i.imgur.com/603Qupg.png and set the color -> https://www.screencast.com/t/7OeUEnYsO
I can’t solve this problem. In preview articles i’d like that all have the same size. Do you have any tips?
I’m sorry, but I’m not sure I fully understand what you are trying to achieve. Could you explain once again with some screenshots, please?
As you will see on the link, post preview are not the same size
https://imgur.com/4F5hNhN
Unfortunately, there is no option for that to make the same height all modules, those are adjusted after post title and excerpt dimension (length of words or letters) and these are the only options that can be used to adjust the flex height, now if you are using the excerpt on letters -> https://www.screencast.com/t/McjF7faoO -> https://www.screencast.com/t/Il7hnKlsy then the flex blocks height will be most of the time the same, it is set on words, then can appear difference because some words are longer then others.
Also, you can set for each post an expert and then that excerpt will be displayed on the blocks => https://i.imgur.com/4d6c7sH.jpg
Also, you can set the space for excerpt => https://i.imgur.com/h4D2RaY.png
