Problem on mobile
I turned off all mobile plugins because it’s easier for me to make the site. The problem I now have is when I go to the post it uses a different header, some generic one. And on other pages that work and look fine, the footer is different. Any solutions to this issue? TNX in advance
Do you use a mobile page? if yes, you need to convert the existing header/footer like this => https://www.screencast.com/t/HrjOBNayd
Please check this topic where I explained each mobile version -> https://forum.tagdiv.com/topic/mobile-version-not-working-properly-2/
