Problem on mobile
https://www.politicaltruthnow.com/
Hi, I have a problem with the mobile version. Sometimes my logo is PoliticalTruth, sometimes it’s TodayNews. I used a pre-built template.
Also I want to turn off the featured images in the post, but the option in theme panel doesn’t work. Please give me solution. Thank you
Please select the viewport on phone, select the logo and change it => https://i.imgur.com/Rm75FmU.png -> https://forum.tagdiv.com/add-logo-newspaper/
You can delete the element Single Featured image with right-click from the Single post template so that in this mode you won’t have a featured image -> https://i.imgur.com/re1XWKO.jpg
