Problem on the mobile
Hi, in the mobile version, if I click on the menu, instead of appearing the menu, the page shrinks and you can no longer navigate.
https://www.professionegenitori.it/
I think the problem is caused by the cache plugin which minified the css https://i.imgur.com/4VNqGe3.png please disable the option, clear for a few times the cache and check the results.
