Hello sir. I have updated the theme and used one of the best single post structure from cloud library. Everything is ok and amazing. But when I have published a new content and went for social sharing, it gives wrong link structure. It shows the same structure for all content which is that one when i created a single post name after importing from cloud.
The new post templates will not affect the permalinks. Try re-saving them in WordPress settings. Simply import a new post template and modify it if you wish or save it as it is. Then apply it for the posts you want. The sharing should not be affected.
Please correct me if I misunderstand, also provide some more details about what exactly is happening.
Dear sir. Maybe i could not make the problem clear. First i have created a post sample using cloud library single post format. Then i applied that post sample for all post through Theme panel. Upto these, everything is ok and working fine. But i see a problem when i go for sharing any content, it shows only one link for all content and that is the post sample link i have created earlier. Please see https://drive.google.com/file/d/1FjmGP0snbvxjrRXzhGZt5WTT6l_VPLUG/view?usp=drivesdk. I think now you will understand the problem. Can you please help in this matter?
