Problem ShortCode Geo Directory
When I try to put a shortcode of the Geo Directory plugin inside a text block with TAGDIV Composer I go to a blank page. I have activated errors but nothing appears and I don’t know what can happen.
go to this url with the screen blank: ../post.php?post_id=4189&td_action=tdc&tdbTemplateType=page#/
If you are using shortcodes or embed codes the you’ll need to set the code in column text or text with title, in text area -> http://prntscr.com/q3q6f6 if this do not work you can try to set the code in a raw html too -> http://prntscr.com/q3q6tf also please notice that is possible that the shortcode you have for geo directory to be provide from some plugin that do not work with our theme.
