I can not cambire the custom sidebar of the homepage under post settings.
even though I set the sidebar XXX is returned to me publicly YYY.
How do I act?
I thought it was a bug
thanks
I’m not sure that I understand what are you trying to do. For post pages and other templates you can chose the sidebar from here: http://screencast.com/t/Ib0vSuhToo
For other pages you can chose the sidebar directly freom page editor: http://screencast.com/t/Eykf2td2E or add an widgetised sidebar element and set it like this: http://screencast.com/t/hI8KFdYVeiG1
Hope this helps!
When editing the homepage,
in the last articles I’ve set a custom sidebar to the existing ones.
For example, I chose the HOME.
This, however, did not appear in the homepage.
the custom sidebar does not appear on the homepage under latest articles
I have tested this using the latest theme version (4.2.2) and worked fine:
– homepage-bg-with latest articles template:
* http://screencast.com/t/bzBXOKXZ
* http://screencast.com/t/wcDYwq1wS
– homepage-with articles list template:
* http://screencast.com/t/iUalUyAv
* http://screencast.com/t/mqFxQW0rVoy
Please make sure you use this right and you set the custom sidebar like I did and also that you have widgets in your custom sidebar: http://screencast.com/t/siiiAwoHWuU
Should work fine.
I tried to do essatamente as I said but it does not work.
I have the latest version of the template. This problem is giving me after upgrading to the latest versions.
How can I fix?
Look attachments
delfinista.
Please disable all plugins and check if the is still happening, also please check for errors in the console.
If nothing works please send your wp-admin user and pass at contact@tagdiv.com so we can check this, also make sure you specify this issues details in your message or send a link tot this topic.
I disabled all plugins. But the problem has not been solved.
I just sent an email to contact@tagdiv.com with user and pass.
Please let me know as soon as possible.
thanks
