Problem tagdiv Composer
Greetings,
I’m having serious problems with Tag Div Composer.
If I try to drag any item to add it doesn’t.
I attach a video.
Where am I wrong?
https://we.tl/t-jFvNz4Xcf1
It happens to me on all sites and with all licenses
Hello @delfinista!
It should be a green place where you can add an element. Try to add a new row and place the element there.
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
If the problem is still there, then contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
We will check the issue and let you know what can be done there.
Hi Bettina,
I did what you asked but I didn’t solve it. In any case, as I told you, I have this problem on all sites and licenses. I created an administrator username for you and sent it to you via email. I’m waiting, thanks
