Problem tagdiv widgets
I have a problem with the Tagdiv widgets in my sidebar. All other widgets work fine, but when I activate a special Tagdiv widget in my sidebar, my entire site gets messed up. The main content has disappeared and the content of the sidebar is suddenly fullscreen.
In my error log I see this:
“2015/10/21 11:36:41 [error] 2558#0: *22186 FastCGI sent in stderr: “PHP message: PHP Catchable fatal error: Object of class stdClass could not be converted to string in /var/www/comnie-limniones/wordpress/current/wp-content/themes/Newsmag/includes/wp_booster/td_block.php on line 131” while reading response header from upstream, client: 80.100.41.11, server: http://www.nieuwetijdskind.com, request: “GET /over-ons/ HTTP/1.1”, upstream: “fastcgi://unix:/dev/shm/php5-fpm.comnie-limniones.sock:”, host: “www.nieuwetijdskind.com”, referrer: “http://www.nieuwetijdskind.com/product-categorie/online-cursussen/”
I have a test site on anther server, same version of the theme, same plugins and there the problem is not.
Hope you can help!
Sincerely, Niels
Try to remove the widget that causes the error, clear all caches then re-add it again and check if the error is still there. If the problem persist please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic.
