Problem Theme panel
My English is not good, I hope you can understand, thanks
My Theme panel this problem and how to solve? Thanks
Not-working
Not-working
Hello lifestylemy,
Please ensure that you are using the latest version of it (Newspaper 7.1.1) and also, the latest version of required plugins (Visual Composer 4.11.2 and Social Counter 4.1). Also, please make sure that this type of problem does noot come from your untested plugins. Please try to disable all the active plugins, leave just Visual Composer to active, clear all your caches, purge CDN file if you are suing the CDN system and install only the plugins that come bundled with our theme and rule out the conflicting plugins.
i test does buy not work.
Newspaper v 7.0.1 no problem
upgrade Newspaper v 7.1.1 not work
I hope you next version can solve this problem
Hello Vlifestylemy,
Please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect your setup page. Also, please provide the link of this topic so we can identify you.
