Problem to import Dental Theme
Hi, how are you? I’m trying to import the Dental demo for my site of seguro auto br, but it’s giving this error: “Did you disable any tagdiv plugins?”, But the plugins are active.
Besides this error, others appear;
wp booster error:
td_api_base :: mark_used_on_page: a component with the ID: tdm_header_style_3 is not set.
/home/server/public_html/site_name/wp-content/themes/theme_folder/includes/wp_booster/td_api.php
wp booster error:
td_api_base :: get_key: a component with the ID: tdm_header_style_3 Key: file is not set.
wp booster error:
The path of the tdm_header_style_3 header style not found. Did you disable a tagDiv plugin?
I’m using an under construction plugin, how will you log in to view?
Can you help me?
Please disable all other plugins except the tagdiv composer and the multi-purpose plugin and clear all caching. try to re-save permalinks and set the header style again in the theme panel and press the save button.
Let us know if you still have trouble
If you do, contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
Bogdan, tks for the quick return.
I did what you told me. I deactivated plugins and only kept tagdiv composer + multo-purpose. I selected the desired header, however, there is no button to save. The problem persists.
I sent email to contact@tagdiv.com.
Thank you
If there is no buton to save settings that is a clear indicator you have to update the theme to the latest version (8.5.1) (use this guidehttps://forum.tagdiv.com/how-to-update-the-theme-2/) and please also disable and delete the multi-purpose plugin you currently have.
Then install it again from the theme plugins section but only after you update the theme.
If you still encounter issues, please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this conversation.
Bogdan, hi!
I send another email. Tks
Note: i use php7.
