Problem to integrate a calendar on newspaper
Hello, I have a problem integration on a part of my calendar / event with newspaper.
On the general page of the calendar ( https://bpe.fun/calendrier-des-evenements/ ) I have no problem, but when I want to visualize an event alone, I get this: https://bpe.fun/evenement/cycle-de-conference-bien-etre/
I have been trying for 3 days to do the integration using this link on EventOn ==> http://www.myeventon.com/documentation/customize-single-events-page/ ,
but I can not! Newspaper is much more complex than the basic wordpress theme and I have no knowledge in php code. I just came to you because I tried to ask for help to the creator of EventOn but since I bought the script almost 1 year ago, I have no more support, that’s what answered me …
Could you help me please.
The default WordPress themes are meant to be as simple as possible. But all premium themes behave differently when it comes to plugin compatibility and other aspects. Some plugins are simply not compatible, when that is the case try another one instead if possible. What you can try is to deactivate all plugins (including caching plugins) except the theme provided plugins and the event plugin. Then check if this has any effect. From the number of errors on the page there are multiple conflicts happening
– https://www.screencast.com/t/ajA3wKTxymhA
