Problem updating to 8.1
Hi, I’ve just updated the theme to 8.1 version (previously I was with 6.5).
I have used the FTP-way, deleting the old folders (both for theme and plugins) and then uploading the new ones.
There is one big problem. In desktop version, the mobile menu appears upon my logo. I have tried to deactivate all the plugins but the problem persists. I have emptied the cache many times, with no result.
Any ideas?
Thanks in advance
It would be very helpful if you could provide a link to your website so we can inspect it, and see this happening.
If a plugin is not responsible, then maybe custom code or modifications or a child theme could be the cause. The mobile menu should not display on desktop, if it does something is not working properly.
Everything works fine now. I made a mistake while setting the test area. Sorry for the false alarm.
