Problem using correct sized thumbnails
In some of my modules, fx Module 16, the correct sized thumbnails are not shown.
However, I have checked in folder at server, and they correct size thumbnails to use in block 16 have actually been created, they are not just used by theme.
What might be the issue, I have also checked that thumbnail size for module 16 have been correctly set.
Please also provide your site’s URL so I can inspect this as I’m not sure about this. Please also try to regenerate thumbnails: https://forum.tagdiv.com/how-to-fix-strange-thumbnails/ ..and re-save your permalinks structure.
Let me know how it goes!
Hi Lucian. The URL is http://www.podcasts.dk
User:User3, pass: user33.
Note how the different the samme images are handled as thumbs at the middle of the page, block 7 and block 16.
Working fine at block 7. Also problems with block 12. I have tried to renegerate thumbnails.
I can’t access your site using the login credentials you’ve sent. Please look into this.
Sorry about this, try user10 and user10
I checked your site, please make some tests and add/use some big size featured images and see if you still have this issue. Also try this without any plugins active, leave only Visual Composer active, also clear cache and purge your files if you use CDN.
Let me know!
